As on that image the far end of part 9 is a simple push fit into the bulkhead, just pop it off and the large bit of foam is just inside it, take this out and it gives the engine note inside the cabin a much more raw sound.
It only takes 30 secs to remove then you can go for a drive and see if you like it, you will notice a difference, if not just put it back in.
If you like it but think its still not enough there is another bit of foam at the other end of part 9 but you will need a screwdriver to crmove a clip for that bit.
Dont underestimate how simple this is to fiddle with, worth giving it a try just because it is so easy.
