sound gen foam put back in
Tried putting mine back in just now, its always been out ever since I had the car. I did like the sound without but at times I felt like my ears were ringing it was so loud. Its much more civilised and refined back in and its got that classic BMW straight-6 noise, whereas before it was more of a howl. However, I do think its a bit less "fun". I think cutting the foam in half or 2/3s of it might be the best compromise between fun and refinement.
Just put one piece back in as I was growing a bit weary after having both bits out.
However, I misplaced both foam pieces stupidly so I had to cut out a similar shaped piece and replaced at the firewall.
Sounds much more civilised now while retaining a bit of the fun factor. Just the right balance imo :thumbsup:
coaldust said:
also just switched the potenza runflats for uniroyal rainsport 3's, and the difference is just shocking, smoother ride, no tramlining and being pulled into ditches on back road, and less road noise, anyone that is running potenza runflats you must get them off asap as they are dangerous and ruin the z4.
Interesting. Was also considering ditching the runflats for the Rainsport 3's. What I'm finding with the runflats (and it might not be them that's causing this) is when I'm driving it sometimes feels there's a little gremlin in the steering wheel just ever so slightly pulling the steering wheel - is that what you were finding?
It's all person preference with the sound generator, but to me it sounds like something is wrong with the car. Tried different configurations of foam, didn't like any, so put it back to stock and am much happier. They should have used the money spent on the sound generator and engineering to design it on the exhaust to make it sound better, it's just too tame for a sports car.
Yorkie Z said:
I never rated this mod. Ended up modifying the backbox on the exhaust. Now that was a great mod and sounded awesome.
I'm having the exhaust mod done in December. Booked in with Pauls Car Welding. Looking forward to hearing it in combination with the sound gen. :evil:
Backbox/muffler delete?
If anyone has a spare foam they no longer need, I'd be very grateful as I'd like to add one back in ?
Just drop me a PM and I'll cover the postage or donate to Zedward.
Really easy to fashion from any old bit of foam mate.... :thumbsup:
Very true. - I'll go and whittle one down :thumbsup:
Yep. Though I don't want it too loud. He's done a few Zs so I'm sure it'll be fine. He quoted £240, I figured that was way cheaper than buying a new box at around £700.
Hi, all the back box delete jobs I've heard have been very loud-beware if it's just being chopped off!
Def too loud for me deleting backbox. Cops can take u off the road here in Holland too if ur too loud. Can get that the pops and bangs on the overrun are loads of fun but i'd grow weary after a while and itd be an expensive refit to change back.
Going to try and transplant the lovely-sounding Sebring backbox from my totalled e36 onto mine but doubt it will fit. Otherwise i'll get a new one.
I think I've misunderstood. The back box is removed, cut open and then a piece of the perforated pipe is removed, a new section of straight pipe is welded into it's place and the back-box is welded back up again. So the back box stays where it is and the exhaust is made louder depending on how much or how many pipes are replaced.
Here's a link to Pauls Facebook page where you can see many mods on different cars.
https://www.facebook.com/Paulscarwelding/
After a week of mine being standard (both foams in), I'm going to remove one again. Far too quiet for my liking. If its too loud again, I'll try and fine tune the noise by trimming the larger foam and experimenting with positioning.
This hits the nail on the head.
Definitely marmite/horses for courses this foam business.
I had both out and got a bit bored with it.
Put one bit back and it was too tame. So I fashioned my own custom foam piece from a bit of old sound insulating foam I had floating about my mancave.
It's about half the thickness of the piece that sits at the firewall and due to the square cut it doesn't 'shape seal' the resonator feed tube.
I found that it gives just the right amount of grunt when tickling the loud pedal but not too loud to be irritating long-term.
