Sony Alpha A380 14.2MP Digital SLR Camera + 18-55mm lens + extras
Timmyboybunter
 Bristol/Bath
Sony Alpha A380 digital SLR camera.
Comes with:
Camera body
18-55mm lens
Samsonite case
Charger and 2 batteries
USB lead
Manual
Selection of filters
Good working condition.
Collection welcome from BS39.
£130
Full specifications
Lens Mount
SONY Α MOUNT: YES
COMPATIBILITY WITH A-MOUNT BAYONET LENSES FROM MINOLTA AND KONICA MINOLTA: YES
Lens Compatibility
MINOLTA & KONICA MINOLTA Α/MAXXUM/DYNAX LENSES: YES
ALL TYPES OF SONY Α LENSES: YES
Image Sensory
SIZE (MM): 23.5 x 15.7 (APS-C size)
IMAGE SENSOR COLOUR FILTER: R, G, B, Primary color
IMAGE SENSOR TYPE: CCD Sensor
Camera
ISO SENSITIVITY SETTING: ISO100 - 3200 equivalent
WHITE BALANCE BRACKETING: NO
AUTOMATIC WHITE BALANCE: YES
TOTAL SENSOR PIXELS (MEGAPIXELS): Approx. 14.9
WHITE BALANCE: TYPES OF COLOR TEMPERATURE: NO
WHITE BALANCE: PRESET SELECTION: Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash
WHITE BALANCE: CUSTOM SETTING: YES
EFFECTIVE PIXELS (MEGAPIXELS): Approx. 14.2
SteadyShot INSIDE
SYSTEM: SENSOR-SHIFT MECHANISM: YES
CAMERA-SHAKE WARNING (IN VIEWFINDER): YES
*STEADYSHOT INSIDE WAS PREVIOUSLY KNOWN AS SUPER STEADYSHOT
STEADYSHOT INSIDE CAPABILITY: Approximately 2.5 EV - 3.5 EV decrease in shutter speed (varies according to shooting conditions and lens used)
STEADYSHOT INSIDE COMPATIBILITY: All Sony DSLR lenses and A-Mount bayonet lenses from Minolta and Konica Minolta
STEADYSHOT INSIDE SCALE (IN VIEWFINDER): YES
Anti-Dust
DOUBLE ANTI DUST SYSTEM (ANTI-STATIC COATING AND CCD SHIFT MECHANISM): YES
Auto Focus System
AF AREA: LOCAL FOCUS AREA SELECTION: YES (9 local areas)
PREDICTIVE FOCUS CONTROL: YES (with moving subjects in AF-A and AF-C)
AF AREA: SPOT: YES (center cross sensor)
AF ILLUMINATOR RANGE (METERS): 5
AF ILLUMINATOR: YES (with built-in flash)
SENSITIVITY RANGE (AT ISO 100 EQUIVALENT); EV: 0 - 18
TTL PHASE-DETECTION SYSTEM: YES
EYE START AF SYSTEM (ON OFF SELECTABLE): YES
AF MODES: Continuous, Single Shot, Automatic, Manual Focus
AF AREA: WIDE FOCUS AREA: YES (auto with 9 areas)
SENSOR: 9 points with centre cross sensor
FOCUS LOCK: YES
Auto Exposure System
LIGHT METERING TYPE: TTL
LIGHT METERING: CENTER WEIGHTED: YES
EXPOSURE COMPENSATION: YES (+/-2.0 EV, 0.3 EV step)
EXPOSURE: SCENE SELECTION: YES
EXPOSURE: APERTURE PRIORITY: YES
EXPOSURE: MANUAL: YES
EXPOSURE: AUTOMATIC: YES
EXPOSURE: PROGRAM AUTO: YES
LIGHT METERING: MULTI SEGMENT: YES
AE BRACKETING: With 0.3 EV / 0.7 EV increments, 3 frames; (in "Drive mode setting")
EXPOSURE: SHUTTER PRIORITY: YES
AE LOCK: NO
LIGHT METERING: SPOT: YES
LIGHT METERING CELL: 40-segment honeycomb-pattern SPC
Shutter
SHUTTER SPEED RANGE (SECONDS): 1/4000 - 30 and bulb
FLASH SYNC SPEED (WITH SUPER STEADY SHOOT OFF); SECOND: 1/160
TYPE: Electronically-controlled, vertical-traverse, focal-plane type
Flash
FLASH POPUP: YES
SLOW SYNCHRONIZATION: YES
FLASH METERING SYSTEM: ADI / Pre-flash TTL flash metering
WIRELESS FLASH MODE: YES (with optional compatible accessory flash)
BUILT-IN-FLASH GUIDE NUMBER (IN METERS AT ISO 100): 10
FLASH COMPENSATION: +/-2.0 EV (0.3EV steps)
RED-EYE REDUCTION: YES
FLASH MODE: Autoflash, Fill-flash, Slow sync, Rear flash sync. High Speed sync. with optional compatible accessory flash
BUILT-IN-FLASH RECYCLING TIME (APPROX. TIME IN SECONDS): 4
AUTOMATIC FLASH: YES (with AUTO and Scene selection mode)
Viewfinder
MAGNIFICATION (WITH 50MM LENS AT INFINITY): 0.74x
EYE RELIEF: Approx. 19.7mm from the eyepiece lens
FOCUSING SCREEN: Spherical Acute Matte
DIOPTER ADJUSTMENT: -3.0 to +1.0 diopter
FIELD OF VIEW (%): 95
TYPE: Fixed eye-level system with roof mirror type
Live View
TYPE: YES - Quick AF Live view
OTHER: Smart Tele Converter
LCD screen
TILTING SCREEN: YES - 2 way tilt
LCD TOTAL DOT NUMBER: 230.400
BRIGHTNESS ADJUSTABLE: YES (Auto Brightness Control available)
MONITOR TYPE: Clear Photo LCD
SCREEN SIZE: 2.7
LCD ON/OFF: YES
Recording
RECORDING FORMAT: JPEG, RAW, RAW+JPEG, 16:9 selectable
CONTINUOUS-ADVANCE RATE (APPROX. FRAMES PER SECOND AT MAXIMUM): Max. 2.5 fps with viewfinder, max. 2 fps in live view mode (approx.)
DATE/TIME PRINT: With PictBridge
DRIVE MODE: Single-frame advance, Continuous advance, 10 seconds and 2 seconds Self-timer, Self-timer Continuous, Continuous-advance AE bracketing, Remote commander
DELETE FUNCTION: Single, multiple, or all frames in a folder
COLOR MODE/DEC/CREATIVE STYLES: Standard, Vivid, Portrait, Landscape, Night view, Sunset, B/W, AdobeRGB
STILL IMAGE QUALITY: RAW, RAW+JPEG, Standard (JPEG), Fine (JPEG)
NOISE REDUCTION (LONG EXP.NR): On/Off, available at shutter speeds longer than 1 second, On/Off, available at the ISO set to 1600 or above
RECORDING MEDIA: Memory Stick PRO Duo™/ Memory Stick PRO-HG Duo™/ Memory Stick PRO-HG Duo™ HX/ SD memory card/ SDHC memory card
IMAGE SIZE M (PIXELS): 3408 x 2272 (7.7M)
DYNAMIC RANGE OPTIMIZER: Off, Standard / Advanced
RAW (PIXELS): 4592 x 3056
NUMBER OF CONTINUOUS ADVANCE: JPEG (L size, Fine): Until memory card is full, RAW: 6 images, RAW+JPEG: 3 images
IMAGE SIZE L - JPEG (PIXELS): 4592 x 3056 (14M)
IMAGE SIZE S (PIXELS): 2288 x 1520 (3.5M)
COLOR SPACE (SRGB): YES
Playback/Edit
WHITE/BLACK OUT ALERT: YES
INDEX PLAYBACK: YES (25, 9, 4 or 5 last frames filmstrip)
ENLARGE (MAXIMUM MAGNIFICATION): size: 14x, M size: 11x, S size: 7.2x
AUTO IMAGE ROTATION: YES
IMAGE ROTATION: YES
INFORMATION DISPLAY: YES
General
DEPTH-OF-FIELD PREVIEW: NO
FOLDER NAME MODE: Standard and Date
