Sonax Xtreme Brilliant Shine Detailer
patriot66
Veteran
 Southport, Merseyside
I bought some of this a couple of weeks back and have used it on my Zed (Sterling Grey ) and my wifes Freelander2 ( Met.Black) this week. I used it whilst drying with a micro-fibre towel and have to say that I am extremely impressed by it. It's quite thick in the bottle which means it doesn't run when sprayed on and helps it to go a long way. Smells nice. Leaves a very slick feel and high gloss when buffed with a second micro-fibre towel. The best gloss of any detailer I have used to date. It apparently beads superbly but my cars are waxed regularly so cannot gauge this fairly. Got mine from Amazon ( SONAX Xtreme Brilliant Shine Detailer by Sonax http://www.amazon.co.uk/dp/B007O9CXHI/ref=cm_sw_r_other_udp_awd_eyn0wb1VZ50ZW ) and at £9 for 750ml I shall definitely be buying some more ! :thumbsup:
Buy some other QD and mix them together and you'll find it goes on a whole lot better and will be less grabby but with the same results and impressive beading.
You can get it from Eurocarparts cheaper than £10 and it's free delivery, pop in this code and get 11% off VCloudSale11. http://www.eurocarparts.com/car-detailing/searchkeyword/sonax
I've used it before but much prefer ODK Entourage as the finish with this is like glass and it's easy on/off.
Been using it on our smart car with very good results, brought it last December and it had no protection but now beads very nicely
Great product and beads really well - an absolute bargain!!
If you get on with it - look up the bargain 5L tubs too and then decant.
As mentioned above..... i keep a mix of Sonax BSD with a more slick QD for the paint.
But i use BSD neat on door shuts, alloys and such like after every maintenance wash.
...gives great results!
Z4M-2006 said:
I mix the sonax with 50cal Stealth last touch..
Makes a cracking combo.
Similar to what I've found, I've now settled on a QD mix of Gtechniq c2v3, BSD and distilled water in a 2:2:1 ratio applied with a fine mist spray bottle
