Some bits left over (junk)
daz05
 Écosse
Aplogies in advance, mostly junk but may be useful for someone. Clearing out the cupboard I have some bits left over I figured it was worth trying to sell before the wife throws it out.
1. I have an Imola red plate holder if anyone needs one, could be cut down and used to secure a shorter private plate. Part number 51117158837, £10.
2. I have 2 trim panels from the rear of the coupe that cover the interior of the tailgate. Useful if your existing ones creak or rattle. Part no.1 left and right. On small clip broken on each but there are not securing clips so no issue with fitting.
http://www.realoem.com/bmw/showparts.do?model=DU92&mospid=49422&btnr=51_6100&hg=51&fg=65
£20 for both or willing to split. Offers.
3. OEM induction scoop that sits behind the grill, the bit that you would remove to fit the RPI sccop. You could possibly use this to modify and create something less restrictive and not ruin your existing scoop if you wanted to experiment in that area. £5
