So I picked my coupe up from the local stealers on Friday after an inspection II and full safety check (complimentary). I was warned that two wheels were buckled but classed as amber status. For the record until this point I was not aware of any issues with tyres, wheels, pressures etc.
Drove to work today with no issues.
However on the way home after a 20 minute run at 70mph the red tyre warning light came on. I pulled into the nearest garage. Looked around and no flats, no obvious damage to tyres or wheels. Decided to use the compressor at the station to check all pressures.
First thing I noticed was that on both rear wheels the tyre valve was so far retracted back into the wheel rim that I could barely get the adaptor on, I have never noticed or experienced that before and only checked my pressures 4 weeks ago! Thought it was a bit strange. Then I check the tyre pressures and all 4 wheels were up at 44+ PSI
I always run my backs at around 36 and fronts at around 32-34, never had any issues with handling or tyre wear. over 40PSI seems pretty high to me? So I reduced them all down.
Tried to reset the tyre light on the way home and it won't go out. I've had a moan at the Stealers and have been asked to bring it in on Wednesday. Just seems strange??
