Hi
Help needed please... Both bulbs that make up the front left corner indicator of my car are always on regardless of whether the lights are set to on, off, or auto. The light warning indicator light is also lit up on the dashboard.
I've switched my hazards on and checked around the car and all the lights work and the two bulbs on the faulty corner are both on so it's not that one of them is out.
When I turn the engine off and remove the key from the ignition the indicators still remain on. The only way to switch them off is, when the engine is off, to put the key back in the ignition, turn it to the first mark and then turn the kry back to zero and remove the key.
Does anyone have any ideas?
Thanks in advance.
ADM
Thanks in advance.
ADM
