Sold 4 x MV4/225M wheels 19"
philipw
 Bristol
Hi All,
I have 4 x MV4/225M style wheels for sale that have been removed from my coupe.
- 1 x genuine - part no. 8037141, offset 39
- 3 x replicas - offset 34 (front), 37 (rear)
Photos below, minor curbing to the wheels and one of the rear wheels is a replacement. There is one crack on either rear wheel as pictured, they do not affect the wheels ability to hold air.
Tyres have minimal life left on the front (passed MOT) & are Conti Sport contact 3, Bridgestone Potenza/Goodyear F1 on the rear (4+mm)
Located in Bristol
Looking for £140 for the set - open to offers.
Nice to see some MV4's pop up for sale..
Not meaning to offend the OP or this listing etc
However and looking at the images, I suspect: that there are potentially 3 x Replica / Copies wheels here and 1x OE MV4.
In image 5 (going from top to bottom), you can clearly see around the centre cap, the number 11. OE MV4 wheels generally have these.
Copies do not :!:
In image 1, of the rear of all 4 wheels - a quick scan and you can see the differences in the castings - on the outer rim, nearest the tyre side walls.
The 1st (left hand wheel - I suspect the OE one) has a completely flat surface.
The other 3, have a pronounced rim, just before the where the rim, meets the tyre.. :!:
Good luck with the sale OP.. :thumbsup:
Good spot! I thought I noticed something last night but I was a bit pissed :rofl:
Left hand rim is defo genuine. The hub where the bolts go through is flat on the genuine but there'sdeep recesses on the reps :thumbsup:
Copies do not :!:
No offence taken, I wasn't sure if they were genuine or not hence not advertising them as genuine.
From looking into it this morning, it seems you are correct. That one rear wheel is stamped with BMW and has the part no. 8037141 stamped on it, offset 39. The other three must be replicas, both fronts have an offset of 34 and the one rear has an offset of 37.
Obviously this impacts what they are worth, so I'm open to offers :thumbsup:
kimwyclef said:
Hi do you have any pictures of them on the car?
Not the best photo but its the only one I have of them on the car.
hi I tried to send a pm unsuccessfuly ... Pm me whereabouts in Bristol you're based and I'll come have a look at the wheels
Hi, thanks for your enquiry
PM sent
