I just replaced the hydraulic pump motor for the top and relocated it to the trunk while doing so. It opened and closed great a dozen times but now I’ve got hydraulic fluid leaking from the drain on the right side. Does anyone know or have had experience rebuilding the hydraulic actuator on the hinge lifter? Do you have a source for the rebuild kits or a reasonably priced dealer for replacement parts. I intend to do both sides as my experiemce with hydraulic systems tells me if one side fails, the other side will be right behind it.
I’m sure this has been addressed elsewhere in the forum but I’m unable to locate it.
