so shes in on wednesday for the oil service!!
SittingBull said:
st8220109
Engine and Gearbox Suspension
Page 1 ofl
February 2009
Technical Service
$tJEJECT
Engine Vibration
rdsnHr-
E85, E86 M Roadster and M Coupe with S54 engine up to 3/08 production
$ITU,ATIO}I
The customer may complain of an engine speed-dependent vibration felt in the vehicle during driving.
CAU$fi
Prolonged heat exposure to the right side engine mount bracket, during the engine assembly process,
may cause the bolts, which hold the engine bracket to the block, to lose the specified tightening torque.
c*ffiffiEcTrsN
Inspect the right side engine mount bracket bolts. If one or more of the engine mount bracket bolts are
found to be loose, replace all four engine mount bracket bolts. Refer to Repair Instruction RA221l 100
for accessing the bracket and tightening torque.
:wink:
yup thats the one, thats the exact print out i took in. The dealers no feck all about it. infact to double check i phoned three different dealers just in case. they all said the same thing. basically feck off you plonker.
