what if you get snow foam on the soft top?Angelus666 said:Always wash your wheels first with a separate bucket, rinse them down, apply all-purpose cleaner, then use brushes and wash mitts to give them a good clean. Never use these same materials on your paint!
As a basic rule for paint.....spray the car down with the pressure washer (get as much of the dirt off), then apply a snow foam to soften the more stuck-on dirt, rinse this off after 5 mins....then was the car with shampoo using a 2 bucket method.
IRD said:Bilt Hamber whose products get pretty good ratings.
IRD said:...Having rinsed it off after the recommended time I wasn’t overly impressed. You still have to contact clean the car using a shampoo and the two bucket method. In truth all it seems to do is extend the length of the cleaning process.
I was probably expecting too much. Generally speaking I don’t let the Z get too dirty before cleaning. So there isn’t really any need for the soaking process usually. I am careful but maybe not as thorough as some of you guys. I’ll try the Bilt Hamber foam and see how I get on with that. Cheers.parabolica said:IRD said:...Having rinsed it off after the recommended time I wasn’t overly impressed. You still have to contact clean the car using a shampoo and the two bucket method. In truth all it seems to do is extend the length of the cleaning process.
Snow foam isn't a substitute for hand-washing the car; it's there to soften the dirt on the surface before you go at it with your sponge/mitt. It's no different to soaking a dirty baking tray prior to washing it thoroughly.
