Snap in adapter
Drjcb198
 East Sussex
Does any one know if a 3GS snap in adapter can be modified to fit the original eject box in the E85
IIRC the snap in was significantly wider than the original eject box( before I had mine changed)
The difference is down to slim normal phones v the considerably wider smart phones ,iPhone in particular
have you access both to offer up and see if a Dremel will help
if not try iPhone against the eject box to see extent of problem
AND read this
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=35627
Yes it can be made to fit by modifying the eject box, might be up for grabs, I would need to swap with your eject box (the bottom bit) though,...IF it is removable.....
showing cradle
