Smooth running values
flybobbie
 Stourbridge
Playing with Foxwell reader.
My understanding is that the engine mang. is adjusting fuel to balance engine, based on variation in rotational speed.
Last two are far from others, but believe within limits.
Thought i would pull the plugs and check the gaps.
Got to admit last time i never checked the new one's just fitted them, some 20k ago.
I tended to find they were gaped right as bought.
Interesting to see what i find.
Like any random sample of data. Quite difficult to use without full context of what it is, what it relates to, how it compares to the 1000s of similar examples out there and why you need to know it. :)
Devil finds work for idle hands. :evil:
But just found out gap values, 1.1mm/0.043 inch and torque 23 +/-3nm.
Sounds like Gov. covid public relations officer.
just one correction, fuel, or rather mixture, is balanced to comply with emission standards, they don't care about engine running
the short and long term fuel trims (lambda additive, multiplicative values in case of bmw) show how long the injectors are spraying fuel
smooth running is more related to misfire detection, which inherently, can impact fuel trims - bad spark plug doesn't burn fuel, so the PCM takes away fuel, meaning negative fuel trims, etc.
Well pulled the plugs, all fine to gap.
Still drop of oil in no.4, seal obviously leaking.
Nice to know what normal values are.
