My fault entirely. Dodgy memory.
Took car in for oil service and system upgrade and forgot about the smartTOP module.
The upgrade which takes a long while failed. I fessed up about the module and they removed it and apparently the car is now taking data so should have it back in 1 piece but will have to re-install the module myself as its not a BMW part.
Hopefully I won't get charged for the update! Anyone else had this issue?
Is it just a matter of plugging the unit back in? I've checked that there isn't a significant firmware upgrade since I got it last year but since the unit is now out will update it anyway.
I reformatted my old laptop recently from Vista to Win 7 and in doing so removed the software for the smartTOP. Downloaded it again and although it says plug the module and then run I did run to check and found that there was a missing driver .dll file. Downloaded the driver pack so shouldn't be an issue when I do connect the unit. It says in the manual if the driver isn't present it will be found via Internet connection. I noted when the unit was installed updating firmware was done in real time over the Internet and they don't seem to supply a firmware image to download and process separately which seems a poor way of doing things. Should you want to update the unit in the car then a wireless connection is needed or a very long cable to laptop! Not sure how reliable a wireless connection would be down my driveway.
Hope this faux pas helps someone else avoid the error.
