Slight Hesitation - BMW Fault Codes
junglie
Evening all,
I have the pleasure of owning a 2003 BMW Z4 3.0i SE manual with 43k on the clock.
All is well apart from a missfire / hesitation below 2000 rpm when accelerating in a high gear (3rd / 4th). It does not always happen and everything is perfectly normal above 2000 rpm. Fuel economy is fine and there are no abnormal noises / smells.
I asked my local garage to run their diagnostics and it came up with '10141 - fault not recognised' or something similar. I thought it may be a crankshaft position sensor, MAF or coil pack but I would have expected those to have registered.
Has anybody heard of these symptoms or know what the code means?
From my limited knowledge, this sounds like the Vanos issue?
http://www.z4-forum.com/forum/viewtopic.php?f=30&t=17204&p=249217&hilit=vanos#p249217
x2. Reset your throttle, that could possibly do the trick (and it's free!).
Could also be a coil breaking down. 10141 - not on this list http://www.z4-forum.com/forum/viewtopic.php?f=3&t=9444&p=191792&hilit=+fault+codes#p191792
For reseting the throttle bodies is the routine:
Ignition on for 10 secs.
Ignition off for 10 secs.
Start engine.
I have seen that somewhere else but would appreciate some confirmation.
Start engine.
Correct :thumbsup: This sorted hesitation issues i once had, although at higher RPM
