^ I would agree with most, except the gear shifting and clutch action improved significantly. It's a night and day difference. That's the main reason I would recommend this mod, because the engagement is precise and direct. All the slop is eliminated, yet the organic sprung hub clutch still has enough give to avoid shocking the drivetrain with rough on/off action. With a lightened flywheel, you can get away with shifting faster because the revs fall quickly. Even when you screw up and don't rev match well, there is less rotating mass so less energy is transmitted through the drivetrain.
The only thing that concerns me is the oil pump nut on the M54B30. A lightweight flywheel can increase the likelihood of it occurring.
