Should be simple enough for any semi-trained electrician to answer I think. I however am not an electrician!
I want to install two of these lights inside the garage:
http://www.diy.com/nav/decor/lighting/outdoor-lighting/wall_lights/Napoli-Oval-60W-Matt-White-Bulkhead-11597651
But as its a rental and I can't go playing with existing wiring to add them to the existing lighting circuit, I would like to have them attached to a regular plug socket so I can plug in, run and fix the cable, mount the lights and turn on/off by just the plug socket. I was about to buy the parts when I noticed the light fitting only has two electrical connectors, live and neutral. So, how would I wire two of these lights to a single cable run to a plug that has Live, Earth and Neutral??
What grade wiring / fuse would it require?
