Hi there
So the problem is that my driver side winbdow does not allign with the seal correctly in the area of lower 1/3 of B-pillar
the problem occours either with softtop and hardtop
so the easiest solution would be to allign the window to sit "deeper" in the seal, but the bmw service manual says nothing about adjusting this dimension of window alignment
my former Barchetta had ragulators which you could regulate in dimensions front-rear up-down and in-out
so, anyone on here with experieence in window alignment?
in the B it took my about two days to get a grip of how it all works, and since then I had windows alligned perfectly
but those firs hundred attempts were a PITA
is it the same with the Z?
