side reflector
Hi
After a driver side reflector as mine is cracked and has water behind it. its clear plastic, near the wheel / front bumper interface, dont think it has any bulbs or anything, just looks like a reflective plastic material like you might see on a bicycle wheel.
Where would be best place to find a new one , ebay perhaps ?
Are they easy to remove / re-fit ?
Cheers for the help
Oh ad its for a 2007 coupe if that makes any difference
I'd have said you're probably best to buy them from the BMW Main Dealer.
Part numbers:
63147162735 - Left
63147162736 - Right
Not the easiest thing to replace but I did one without removing the bumper. Buy some spare plastic rivets as you might break some when you take out the 4 or 5 from the arch liner. Then bend it back, swear profusely and reach in to change it. Best to buy the metal washer/bolt things as again you might damage them getting it off. They unscrew with a socket (8 or 10mm), you'll see how it works on the new reflector. Basically it's a plastic rod with no thread and the metal washer/nut cuts a thread into it. Two lugs to undo. Bought from BMW, no more than £15.
