Side light bulbs
bz4kev
wirral
Can anyone recommend some sidelight bulbs for E85 got some from ecp and they look yellow πŸ˜’ need white led I think as have hids and white fog light also looking for highs beam bulbs in white to match can anyone recommend some good led bulbs
Scooba_Steve said:
Do you have Halogen with a HID kit or factory Xenons?
on a side note I see you have led number plate lights I ordered some but when they came the connection is completely different did you have to change fitting or not if not which ones did you get any links thanks
Get some OSRAM or Philips W5W LEDs and code out the bulb checks. Don't get no-name ebay ones or any CANBUS compatible ones, you'll end up replacing them! If you have a set of 4300 K HIDs the 4000 K LEDs give a subtle contrast.
When I ordered the LED number plate lights the parts guy knew the connectors that were needed, you just unlock the connector, push the tab in on the metal pin and slide it out then pop into the new one.
You can get proper oem led rear number plate lights. You just need a special connector (If memory serves me right, I'm sure it was green/turquoise in colour) . I think mine are from a 1 series.
bz4kev said:
Thanks for that great will look for them. These are the reg plate leds I got E657159B-CC88-45C3-B312-54CEA2D9B781.png
That’s the ones I’ve got.... very bright,
yes you can change the conector there cheap, or just cut the key tab off.
I bought some Halford's HID-effect ones for Β£8. They look the part and haven't gone pop after 6 months already...
