Hi, I'm a noob so apologies in advance...
I'm looking for a Z4 right now and I've found one that I was wondering if I could have the benefit of your collective wisdom.
I am going to get it inspected if I proceed but maybe if you guys see any red flags I won't bother...
It's a 2005 2.0i with 65,000 miles that has been a cat D write off.
I've seen pictures of the damage that caused the write off and it does look genuinely superficial. It was hit from the rear, so I don't think any serious damage to the mechanics were caused.
There were advisories on the last mot
Steering warning on dash
Play in os track rod would need 4 wheel alignment
front brake pads at 9mm rear brake pads at 8mm discs corroded
excess play in track control arm brushes
In addition, the door/boot opening indicator is malfunctioning. (Apparently the guy who repaired the bodywork "doesn't do electrics"). So it indicates they are open when closed and vice versa.
We got a flat tyre indication during the test drive.
It's priced at about £5k
Thanks in advance...
