Ducklakeview said:Hammerite is too thick IMHO. I just wire brushed mine on the grinder, sprayed brake cleaner on to degrease, and put them in the Black & Decker Workmate!......Sprayed with a couple of coats of metal protecting paint from Screwfix, 10 months on, they look fine and haven't flaked/chipped.....
Mike
+1 :evil:Ewazix said:Ducklakeview said:Hammerite is too thick IMHO. I just wire brushed mine on the grinder, sprayed brake cleaner on to degrease, and put them in the Black & Decker Workmate!......Sprayed with a couple of coats of metal protecting paint from Screwfix, 10 months on, they look fine and haven't flaked/chipped.....
Mike
The title created an image that I couldn't shift, it's just got worse![]()
PerryGunn said:To stop corrosion once clean, I wipe them (and other areas) over with ACF-50 - it's an anti-corrosion liquid that was made for aircraft, I was told about it by a biker friend
Quickly googled a review http://www.mslmagazine.co.uk/tested-acf-50-corrosion-protection-review/
andy.c said:PerryGunn said:To stop corrosion once clean, I wipe them (and other areas) over with ACF-50 - it's an anti-corrosion liquid that was made for aircraft, I was told about it by a biker friend
And also great at cleaning the engine bay up as well its great stuff
Mike
