Shelf Clips
RROB
Some plastic clips that help fix in place the raise and lower shelf in the boot to the hinges ....
Tried asking local dealership..... I don't think they could be bothered to check if its s serviceable part....
my shelf was not properly fixed I think it needs 4 in total....
have a look on here -
https://www.vehicleclips.co.uk/parts-by-make/bmw-plastic-trim-clips-fasteners.html
Or fleabay
tH
Or fleabay
Thanks... I did look earlier but unsure what to call them "boot shelf fixing / clip" ?
It would help if you could get the parts number, see if you can locate them on this
https://www.realoem.com/
That's what was on it.... I did find it using https://www.realoem.com/ its described as a fuse ! but ill check out parts number with BMW and order if I can....
Thanks both.....
Thanks both.....
rob, any joy with this in the end? I'm after the same part(s) (the black cips) and can't seem to find them on realoem.com :(
Don’t know why it is called a fuse but there are 4 and it is item 4
Yours could be in the bottom of the pit where the motor pump lives
bte123 said:
PDJ said:
Williams Manchester priced me some for me less than £5 each
thanks for posting so quick. that's great news, i'll give me local stealer a call.
ah shxt, my fault, i think we're on crossed wired. i'm after the clips that attach the shelf to the metal bracket.
There are two complete shelves (with the clips) on ebay (one is open to offers, if you could get it at £100). I know its a lot but these aren't available on their own.
https://www.ebay.co.uk/itm/09-15-BMW-Z4-E89-REAR-BOOT-TRIM-PANEL-COVER-PANEL-7341663/293718799152?hash=item4463013330%3Ag%3Aa4wAAOSwLSBfUKye&LH_ItemCondition=3000
https://www.ebay.co.uk/itm/BMW-Z4-E89-Convertible-2009-16-Roadster-Rear-Boot-Trunk-Lid-Trim-Panel-Cover-Net/324164968927?hash=item4b79bce1df%3Ag%3AbiQAAOSwShheu-70&LH_ItemCondition=3000
If you have the broken ones its an easy repair
