setting clock
zforce
I know this sounds stupid but my wife and I purchased a 03 Z-4 about 2 months ago and now with the time change I can't figure out how to change time and seems nothing in owners packet.She has the factory in dash CD.Please help and thanks. :headbang:
Page 48 of the 2003 manual:
To adjust
Ignition key in position 1 or higher:
Hours
1. Keep button 2 pressed for several seconds
until the hours are displayed and
the colon flashes
2. Press button 1 repeatedly until the
required hour is set
Minutes
3. Press button 2 to switch to the minutes
display
4. Press button 1 repeatedly until the
required minutes are set
5. Press button 2 to confirm the settings.
The set time of day is transferred to the car
radio display or appears in the instrument
cluster display.
Display mode
In ignition key position 0:
Press button 1.
The time of day is displayed for several
seconds.
LoL
Just done mine too, was playing with it on the way to work but thought it was best to watch the road.....
PaulN
yah, i started fiddling with those 2 buttons as I was driving and it flashed "RESET" which scared the heck outta me. I just stopped and restarted the car and it seemed to forget the button I pushed.....I think.
I will do it your way now.
Rosie
Yeah I hadn't gotten around to changing mine yet. Was fixing to take a peek at the bible myself.
if only there was a search function on this forum:
http://www.z4-forum.com/forum/viewtopic.php?f=12&t=185
I've tried this, and it hasn't worked. Tried it in positions 0, 1, 2, and 3. I press button 2 for ages, and nothing happens.
should work, mine's an 07 and it works as stated.
Button 2 is your oil check button. Turn ignition switch on but don't start the car. Press 2, hours will start to flash. etc, etc.
I was going to point out that in mine you have to have the time on the radio aswell to change it, but was beaten to it. :thumbsup:
on a slightly different note does anyone know if you can get the time to display if you fit an aftermarket HU.
