Service & MOT Question!
Nova2k7
 Halifax - West Yorkshire
Well seen as I’m going to be taking the car to Europe this year I thought it would be best to make sure the car is up to its best. So I’m looking at the best place to get a good service and MOT. Any ideas how much I should expect to pay for the below items? And where the best place around Halifax/Huddersfield/Bradford is to get this done?
Undercarriage
• Change oil and filter
• Check Transmission for leaks
• Check rear axle for leaks
• Check power steering for leaks, check fluid levels, add if necessary
• Check steering for absence of play. Condition of suspension track rods, front axle joints, steering linkage and joint disk.
• Grease wheel-centring hubs
• Check brake system connections and lines for leaks, damage and incorrect positioning.
• Check for free movement of the parking break cable. Adjust if necessary.
• Check half-shafts for leaks at flexible boots
Engine Compartment
• Read out diagnostic system
• Check engine cooling system/heater hose connections for leaks. Change coolant and Check coolant level and anti-freeze protection level.
• Check level of break/clutch fluid in reservoir and add if required.
• Re gas air conditioning
• Replace spark plugs
• Replace air cleaner element.
• Change oil in manual transmission while at normal operating temp
• Change oil in rear axle while at normal temp
• Check clutch for wear.
• Brake fluid service
• Cooling system service
• Oxygen sensor service
Body/Electrical
• Preform battery load test.
• Change wiper blades
• Oil roof, boot, bonnet and door hinges
• Replace micro filter
Other Items.
• Vacuum leak causing revs to increase while breaks applied.
• Loud creaking from behind the passenger seat requires investigation.
• Knocking from front. Believe to be anti-roll bar? Track rod end?
• Replace front drivers side headlight washer pump
• Front bumper under tray damaged
I'm not aware of any BMW indys in Halifax but there a few in Huddersfield and Leeds
Peter Van Der Veer is in Marsden so a bit of a drive but I've heard he's very good.
not sure about service, but I just booked my MOT at VW SDtockport, £19.95, may be worth trying your local VW garage and see if they have the same offer on
Is this the equivalent of an Insp 2 ? If so, my Indy quoted me £264 incl. VAT last week, not including any work required outside the specified service items.
That power steering fluid check won't give you much value for money....
ok well ive just had a quote come in today from a BMW specialist in Huddersfield. he hasnt however covered some items on my list.
