Liam, it was not difficult, 1 hour a side I recon.
Car on the flat, in reverse and handbrake on, engine off. Crank steering fully right if working on left and vica versa
Slacken off wheel nuts
Jack car using jacking point, I use a piece of wood between the car and the jack as well
Make the car safe, you can leave it on the jack, but I like to add a stand under the car just in case
Remove wheel
If on the left front, near side, you will see a wire coming out of the calliper. Chase this to a box on the wheel arch lining and disconnect. Then free the wire from the lining, the upright and the calliper. All are small rubber connections and just "pop off or out"
Facing you is a big flat spring, this needs to be pushed away from the centre of the wheel and it will pop off.
On the calliper above and below the piston (inside facing the engine) you will find two rubber/plastic caps, pull these out. Inside are Allen bolts, undo.
This frees the calliper and the whole lot should slide off of the disc, unless there is a ridge on the disk which might need taking off with a grinder or dremel.
One pad has a spring that holds it into the piston, the other/outside one does not, the pads should now fall out or be pulled out of the calliper.
I used a bit of solid copper wire to hang the calliper from the road spring while doing other jobs....do not let is pull on the brake fluid line. The piston is clearly visible as is the dust seal around it.....is the seal pushed in all the way round? There is a kit to replace this and the O ring on the piston, I did not have one today but will do this after christmas. Either way, can you push the calliper back in, I use a g clamp, if so then this is not stuck.
The cage will still be mounted to the car, you can leave this if you want, or 2 17m bolts and some grunting will have it off.
I cleaned up the groves and mounting faces of the cage and the pads with some "gunk" and a toothbrush, a flat screwdriver and some sandpaper.
Once clean, either mount the cage or if left on the car, coat these surfaces in copper slip. The Allen key tightened bolts for the calliper were also coper slipped for the record.
Reassemble is the revers of destruction, but be careful to do all the bolts up tight and replace the two plastic caps as these keep the crud out of the mounting pins.
Refit wheel and torque the bolts when on the ground. Pump brake peddle a few times to ensure the piston and pads are back against the disc.
Preventative wise I would recommend copper slip on the pads and the bolts to stop them corroding. I would recommend not jet washing the hell out of the callipers directly and I would keep an eye out on the free movement of the pads and if they are sliding or not.
