It says -Your BMW Sdrive201 requires your attention. Then, We recommend that you schedule a service appointment soon. We will help with: and no more after that. It does not say what they are going to help me with. :headbang:dr_john said:It must have said Sdrive20i rather than Sdrive201.
Was there no further message?
Surely if you have the app you #should be able to check if it is approaching a service or something.weegeoff said:It says -Your BMW Sdrive201 requires your attention. Then, We recommend that you schedule a service appointment soon. We will help with: and no more after that. It does not say what they are going to help me with. :headbang:dr_john said:It must have said Sdrive20i rather than Sdrive201.
The car was serviced on the 26 January :!:enuff_zed said:Surely if you have the app you #should be able to check if it is approaching a service or something.weegeoff said:It says -Your BMW Sdrive201 requires your attention. Then, We recommend that you schedule a service appointment soon. We will help with: and no more after that. It does not say what they are going to help me with. :headbang:dr_john said:It must have said Sdrive20i rather than Sdrive201.
Just had a reminder from BMW that my 520d is due a service NOW!!!
When I looked on the app, it's an oil service with 1100 miles left to go. :headbang:
Yes and booked inZed Baron said:Is it due its MOT?
It'll be a warning to tell you that its dueweegeoff said:Yes and booked inZed Baron said:Is it due its MOT?
Just taken a delivery of a code reader that plugs into my laptop. With a bit of luck we might just get to the bottom of this. :driving:Zed Baron said:It'll be a warning to tell you that its dueweegeoff said:Yes and booked inZed Baron said:Is it due its MOT?![]()
weegeoff said:Just taken a delivery of a code reader that plugs into my laptop. With a bit of luck we might just get to the bottom of this. :driving:
Just tried the code reader. I am not tec savvy. I haven't got a clue what to do with it. :headbang: and No it wont fit. The good news is .It said there were no fault codes.Zed Baron said:weegeoff said:Just taken a delivery of a code reader that plugs into my laptop. With a bit of luck we might just get to the bottom of this. :driving:
If it is the MOT reminder, you can reset it yourself (without a code reader)... its only there so you don't forget to get it done![]()
Just tried the code reader. I am not tec savvy. I haven't got a clue what to do with it. :headbang: and No it wont fit. The good news is .It said there were no fault codes.weegeoff said:If it is the MOT reminder, you can reset it yourself (without a code reader)... its only there so you don't forget to get it done![]()
