Hi every one , newbie here so please be gentle ,
a month or so ago my screen washers stopped spraying , when I looked into the issue the filter below the pump was blocked so did the usual clean out and blow system clear of any debris, when I then tried them all was good loads of pressure and sprayed great , there's still issue though. here's what's happening ;
1. start engine pull stalk loads of screen wash
2. pull off and get moving , pull stalk for screen wash and nothing happens maybe a trickle but not enough to get to screen then nothing at all while the car is moving.
3. pull over stop the engine
4. re start the engine pull stalk and screen wash works just fine plenty of spray
It seems that when the car is moving I get no screen wash , but if the cars stopped and stationary then restart the engine I get screen wash, Ive even pulled off spraying the screen but the n when I ask for wash again I get Nothing, all was fine until they clogged up , ive even changed the pump in case there was a bad connection but no change. Has anyone experienced this or might now a solution.
would disconnecting the battery do anything ? and does anyone know if the FRM controls screen wash ?
head lamp washers work fine as well while moving , its a weird one !!!!!
