Hello all!
A quick query regarding the inbuilt professional sat nav in my 56 plate coupe. Until recently I used to get an audible warning when approaching a fixed camera and this has now stopped. Any ideas how to reinstate this feature?
Hmmmm I thought I had read the 2010 update supported post-code search and speed cameras. Must have been an illegal copy as can't find any genuine ones that mention speed cams.
You might have sdeen some of the newer systems supporting that, as they're hard disk based and can be updated much more easily. However our Z4s use something from the Hadean age!
There is a whole lot of info with regards to getting this info on the disk. However, the assumption is that you HAVE to own the OEM disk as a base before you copy it for your own use.
Hmmm. So, the disk says: "DVD 06-2, Road Map Europe HIGH"; on the back it says NAVTEQ in holographic writing around the hole in the middle. Last time it came back from it's service (at the main dealer) the system had been updated to include a new camera locally. Any more ideas?
No audible warning, just an icon of the POI (Place Of Interest) when that's near enough. It's also just a 'proximity warning', it doesn't check if the POI is actually *on* the road you're on, just if it's nearby.
