Sat Nav Drive Removal Tool
m0gsi
Hello All,
Do you know where I can buy a sat nav dvd drive removal tool?
I tried buying the BMW 83300493099 from ECS Tuning but they are out of stock.
I can buy and ship from the USA through my freight forwarder. I did try and buy a generic one on amazon but it is too wide and thick.
(https://www.amazon.com/gp/product/B0007TC9LW/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
Chris
Two/four unused rivets (whatever size fits) and gently push the tops towards the outside of the unit, keep the pressure on and it will gently slide out :thumbsup:
Thanks Andy
I bought some 1/8inch rivets which fit in the holes nicely but no luck :( I wonder if they are too short
How long do you need to put the ends in?
m0gsi said:
Thanks Andy
They may need to go in further than the rivets. As srhutch says a couple of small screwdrivers will do. You’ll feel a slight resistance when you push them sideways and that’s the tabs being pushed back against the unit releasing the locking mechanism allowing it to slide out
Edit: whatever you use needs to be long enough to push the tabs marked by the arrows back in far enough to release from the black cage
