All,
My Z4MR has loud valve noise from once end of the cylinder head.
The car only has 20 000miles on it and has been doing it since I bought the car at 17 500 miles.
I have reported in 3 times and keep getting told it is "normal" so the garage refuses to look into it at all.
I understand that the valve train design allows for wear and the the clearances are re-set with shims periodically.
I believe that at this mileage I should not be experiencing this valve noise and that it is caused by a fault... possibly lack of oil or low oil flow / pressure to 1 end of the valve train hence excessive wear at this 1 point.
The problem is, as the engine is designed to wear garages will not look for a fault they just keep saying "its normal" without taking into account the low mileage and they will not actually look for a fault.
I have asked them to interrogate the BMW warranty database to look for similar faults at this mileage to see if BMW can advise if there is something wrong and again they are not being cooperative.
I am trying to generate a poll that will show this data...
