Ok so here is what happened and what I found out along the way
So it started like the traction control cutting in as the road surface was poor, but it was a miss fire it stuttered along a few 100m then cut out and coasted it re started on the key and carried on around 600mm to work
Clocked on returned to the car read the codes
Combustion chamber igniting failure cylinder 5 (or words like that) at this point the engine is off so I thought I would re start the engine to see if any other cyclers where affected but it did not turn a full turn before it stopped dead
It looked like a plug and coil at first
Made a call to Darren Wood (note he is booked up until late May) and one of the staff said I should turn it over by hand it was hard to turn by hand with the plugs in and lumpy so plugs removed and it turns over but spat out a spoon full of fuel from cylinder 5
Called Daren back he suggested am injector stuck open
So timed the call to the RAC for the end of shift
Tried to turn the engine over with the plugs out on the key but only a wiz type sound NO click for the solenoid
This was repeated by the RAC man and as there was not starter motor locally he arranged for a low loader to take me home
One of the operators at work came out to look and we tried to turn the engine over on the key it does not move "See told you" and I turned it over by hand at which point he was covered in half a litre of fuel as it ejected from Cylinder 5
So it becomes clear that the injector was open all the time and filling the cylinder with fuel and the first time I tried to turn it on the key it hydro locked the clear risk here is a bent rod but with very little inertia and the engine not firing up a low risk.
Recovered home
injectors off the car how hard can it be to get some well BMW and Bosch will have so in July if you are lucky and at £325 each so £1950
No one else has any I did try
So contact Simon Thorpe Motors and John at JC Racing both brilliant via text with help so I end up driving 20 miles to a works unit to pick up 6 second hand injector and the man John had recommended said I could have them just have them but I would need to get some new O rings
Back to BMW £140 for 13 O rings or 22 as the ONE from the fuel pipe to fuel rail only come in a bag of 10
All fitted
Tried with the starter motor no go so new starter motor fitted it spins over
Oil changed as fuel will have got into it not worth the risk
Spun over until oil pressure shows on dash gauge ( I fitted one)
Plugs in coils on all back together and it runs
Drove it a short test and it came back sounding like a Millington in a MK2 Escort Power was ok above half revs (I did warm it up properly) but horrible below 2500 and tick over was only just managing to stay running
Now the next bit could be luck but found one thing the pipe between the air box and the bit in the bumper was not lined up so an air leak but before any sensors and I fiddled about with the Vanos connection
Started again and tick over spot on and drove it again and pulls like a train as it did before
So the man who gave me the injectors (very nice man) also knows the S54 engine very well his opinion leave it standard as in the real word it is faster than tuning it for a few BHP at the top end and loosing 3 times lower down, but make sure you have the Vanos serviced as this is what makes it so drivable as I found out when something made mine stop working it was gutless low down almost like a lumpy turbo lag
Hope that makes sense and may help someone there is a bit more detail but that is enough typing and probably enough bad spelling for one night
Recovered home
All fitted
