ruggedscot
Are there any links to how to change the running lights on an E89?
Is it not a quarter turn to remove the bulb and holder?Maniac said:Super simple if you're talking about the halos. Standard H8 figment, unscrew the plastic top caps, pull apart the retaining clip around the bulb and out comes the bulb.
You do benefit from having tiny hands for this task...
Nictrix said:Is it not a quarter turn to remove the bulb and holder?Maniac said:Super simple if you're talking about the halos. Standard H8 figment, unscrew the plastic top caps, pull apart the retaining clip around the bulb and out comes the bulb.
