runflat tire pressure warning light just popped up
p28msc
hi All
my warning light popped up whne i was smoothly driving down the motor way BUT tyres are not run flats
stopped the car and i cant see any damage so apart from checking the pressure does any know any other tips?
also need to know how to turn the light off?
Turn car off. Hold RFT button next to the roof open buttons. Turn engine on, light will go yellow, then light will switch off.
Check your tyre pressures, they may not show signs of dropped pressure, but best to check. It may be only a few psi, but better to check :thumbsup:
They just don't go off, check your pressures one tyre will be lower than the others.
On the centre console is a button showing a tyre profile with an exclamation mark.
With the engine running, hold this in for about 10 secs.
Forward of gear shift, picture of U shaped tyre section and '!' inside. Be sure all tyres have proper pressure before resetting.
Mine has just gone on randomly before, all 4 tyres were fine. If it had kept on happening I would've taken to the dealer.
ok so i pressed the button in for a few seconds and the symbol went from red to yellow but didnt go out?????
Start engine but do not drive off.
Press button until yellow light on instrument cluster lights up.
Drive off and after a few seconds light should go out as the system resets.
If it doesn't reset you may have a problem with the system itself.
cheers Dav ill give it a try, gotta ask why the wheel nut name?
