RTAB limiters...where from...?
As per title I’m trying to source a set for the M roady, Turner motorsport in the states need a call to complete the order which I did, but the line is so bad the guy can’t hear me... :roll: Is there anywhere in Blighty I can get a set apart from the guy selling them on the bay for £150 per side...? :o
Many thanks.
I thought the Turner RTAB limiter kit was $50. I installed a kit from PSB, they are a floating rather than fixed design, easy to install and fill in the space either side.
https://www.ebay.co.uk/itm/4-x-BMW-3-Series-E46-Trailing-Arm-Poly-PSB-Bush-Movement-Limiters-1998-2005-/182480764879
You sure they fit our cars properly? The RTAB part number they give is not the same that is used in our cars....
I would try either Hack Engineering, know they have a kit available or also Roy at Crest Automotive (formerly CA automotive) will no doubt be able to get in or will have in stock Turner or Rogue limiters.
I have the turner ones too, available after next week when my rear suspension gets the heave ho! :thumbsup:
