Can't seem to get to the bottom of this. It doesn't always do it, but when it does, it runs like a pig for a few seconds until I pull away and start driving as normal.
I replaced all the ignition coils with brand new Bosch ones and also replaced the CPS sensor with a new BMW one.
Anything else that could cause this? It pops a few times, revs drop quite low as if it's about to stall, so I put the clutch back down and then it's ok to drive away.
Spark plugs I assume were changed during the inspection 2, although I will double check this with the indy I used just to make sure.
If possible, i'll get a video of it happening. That might help diagnosis.
Car runs perfectly fine otherwise and theres plenty of power there, so i'm not too worried. It's just a bit embarrassing and annoying.
