Rooftop motor power cables
Hello, today i removed rooftop to see theres missing one cable in socket for i think should be power for the roof motor.
The motor itself wasnt connected (there is also no power cables for the motor on the roof itself). The motor was without plastic case, so obviously somebody tried something before..I tried to connect motor on 12v battery and its spinning. I didnt saw any ripped off cable or anything on the roof, but theres just one cable from roof on the passenger side. And there are two socket on that side in the car.
I tried to reach my hand under back Seat Plastic where all wirings go, to feel if theres any loose cable which could be the one from the socket, but no luck. Does anybody have a idea what could happened there? I just bought it a few days ago.
I’ll need to check wiring diagrams but I think that’s the supply to the heated rear window… hardtop or soft
In that case, do you know where the green and blue cables from the roof motor (power cables) are heading to? because i didnt had them connected on my rooftop motor.. i saw them on every video, but i cannot find where they continue.
Those are all connected on the passenger side (assuming a RHD car)
Get the cubby storage out and unscrew the retaining screws you should find the 3 connectors and roof control module that side to check if they are plugged in
