Hi
I have a problem with my roof on my Z4 E89. When holding the button down the boot will open, the rear screen will go onto the roof and the roof and screen will go into the boot .. however it stops there and the boot stays up and doesn't close. If I press the button to put the roof back up again then it all closes as you would expect.
Is this a common issue? .. is there a switch or something I can check? (I ran a diagnostics check with a Foxwell and there are no fault codes)
Phil.
Phil.
