Roof storage comparment question
mickl86
very common question probably but if the base of the roof compartment was folded up, would the electric roof mechanism still work or would the car simply not allow you to do it?
Only asking as the manual doesn't state that the mechanism won't work, just that if could cause damage if you left the base up and tried to open the roof.
mickl86 said:
very common question probably but if the base of the roof compartment was folded up, would the electric roof mechanism still work or would the car simply not allow you to do it?.
If your talking about the shelf in the trunk..... if it is the up position, the roof will not open. There is a micro-switch that is engaged when the shelf is in the "down" position.
+1 on micro switch. You'll get an orange warning light, and the roof will not go down.
In the boot there are two black handles.
Turn them both 90 or 180 degrees and it lowers or raises the "parcel shelf".
roof won't lower if the shelf is in the upper position. Upper position is useful if you have larger item in the boot - but obviously the roof won't lower.
