roof SOS
Aggelos
I have a problem with the Z4 roof. I did the engine that was not working, I cleaned it with oil and moved it back and everything was okay. The problem is that it does not open the roof while the engine sounds to work properly. in closure, it closes very comfortably and very fast. Thanks in advance.
I'm sorry Fella, but your English is not good enough to diagnose the issue from your comments.
Can you get someone to translate more accurately for you. ?
Roof motor not opening the roof even though it sounds as if it's working.
Motor has been cleaned and put back in place.
Still not opening the roof.
Roof motor closes the roof ok.
Either that or it's a question about runflats and the rear springs have failed! :rofl:
check emergency release valve and bleed the system ,seem like you have air in the system . Just open and close 4-5 times and it will goes back to normal ,check oil afterwards
