Roof not closing after I did some coding in bimmer code
Teejay2o1o
New member
Hello All,
I have used Bimmercode to fix one of the issues that I have (in other thread) and now my roof top is not closing and the close button is blinking in red
Any help will be appreciated.
If you can list what codings you have done with Bimmercode, then it may help someone to come up with the answer, but on the other hand it may just be a coincidence that the roof has gone faulty at the same time.
Whatever machine you are dealing with computer codes can have unintended consequences, you need to carefully write down all the changes you make then you can reverse them in the same order. If you are lucky there will be a return to factory setting but not always.
Top
