Roof motor- separating failed unit
bigwinn
Elite
 Lincoln UK
Site Supporter
Hi all
I’ve got a failed roof motor and a shiny new one
However I can’t separate the old motor from the spacer
Can’t see any obvious screws etc so assume it’s rusted in place and needs a whack?
Stuart
Ah the joys of dissimilar metal corrosion.
Pretty sure it should come apart without any other work, assuming you have the plastic disc out already?
Make sure you put all the protection on the spacer as that's what you're re-using.
If the motor is duff then it doesn't matter so much to damage that.
