Hi guys, just got to tell you about my roof motor. Bought my zed about a year ago and 1 week after the 3 month warranty ran out the roof packed up working
Gutted after learning about the s**t design and water ingress etc. But soon learned how to do it manually, could live with that until i would eventually get the motor replaced.
The electrics still work perfectly so was able to unlatch and lock back down using the consul button when the weather permitted
Now the best bit. After frequently washing and cleaning the roof i suddenly noticed that the water was draining out from under the car from the drain hole. It left a brownish green stain on the floor with thick greasy looking debris in it. I knew that there was water build up inside, you could just see it when the roof was down looking down where the motor sits (you need a torch cos the roof motor housing prevents much light getting in) I was gonna sort it eventually
Now a week or so ago the weather turned nice enough to have the roof down, so pressing the button on the consul i heard the roof motor humming away like a goodun, not heard that since it packed up! Quickly i went into the boot re-seated the boden cable, checked the parcel shelf, got back in pressed the button and the roof went down! i thought BRILLIANT! Pressed the close button and the roof closed and locked i thought EXCELLENT! Really chuffed.
Have opened and closed it loads of times now. The operation is smooth and fast like it had never packed up. Sooooooo chuffed!
So anyone with a dead roof motor, i would make sure the drain hole is clear and give the motor a chance to dry out before shelling out for a motor replacement and hopefully your motor comes back from the dead like mine has.
Thanks for reading. Cheers.
