I found water had leaked into the passenger side of my 2004 Z4 2.5 a couple of weeks ago and not knowing which of the common faults I was dealing with, blocked drains, door membrane, pollen filter, seals etc, I decided to book it into my local BMW Dealer to have a look at it,£££ Ka Ching, £99 to look at it. Then comes the first phone call, £££ Ka Ching, door is not aligned correctly but they can do that for a price, £££ Ka Ching, roof motor is sluggish, suspect that there is water in the housing, due to blocked drain, £Ka Ching, they will have to remove the roof to check this out, ££Ka Ching, if they find the motor is damaged they quote me to replace the motor.
Anybody care to guess what price we are up to now, bear in mind this is a 2004 model valued at £5000 at most. Then comes the next ££Ka Ching, if they find the wiring for the pump has been damaged by the water, they might have to replace part of the loom.
At which point does it become uneconomical and you should walk away ??? I am sure if you had a crash an insurance company faced with these costs would simply right it off
