Good day, everyone!
After the winter period, my roof has stopped functioning. There is absolutely no reaction when I press the buttons: the lights don’t turn on, the windows don’t go down, and the motors are silent.
Here’s what I have already checked and done:
Checked the micro switch in the trunk — everything is fine.
Inspected fuses 12, 31, and 55 — they are intact.
Charged the battery and then replaced it with a new one — no changes noticed.
Tried to initialize the window lifters using all available methods from the internet — without success.
When I removed fuse 31 with the ignition on and then put it back, the roof lights briefly lit up.
Checked the red flag in the trunk — it’s in order.
Opened and closed the roof manually — no problems.
What I have figured out:
The initialization of the window lifters probably doesn’t work since the glass doesn’t rise automatically.
I noticed that folding the side mirrors also doesn’t function: the fuse is intact, the windows are adjustable, but the mirrors don’t fold.
I realized that I can’t handle this without outside help!
I kindly ask for your assistance and advice! A new cable and roof control module should arrive soon, but I have doubts that this will solve the problem.
Thank you in advance for any help!
I'M READY FOR SUMMER! I solved the problem! It was all his fault(CONVERTIBLE TOP LIFT CONTROL MODULE). I replaced it with a new one and couldn't believe that the roof started folding and closing!
Thank you all for your help! I hope to share only positive posts from now on!
