Emergency actuator
If the electrics or hydraulics fail, the soft-top can be raised/lowered by means of the emergency
actuator.
To raise the soft-top using the emergency actuator, the following procedure must be followed:
- Open bypass circuit on hydraulic pump unit by pulling cable.
- Release soft-top stowage compartment catch by pulling cable.
- Raise soft-top to windscreen top rail by hand.
- Engage windscreen top rail lock using Allen key.
For lowering the soft-top with the emergency actuator, the procedure is reversed.
Opening bypass circuit on hydraulic pump unit:
In the boot on the left-hand side below the soft-top stowage compartment base there is a
release cable with a plastic pull handle. The plastic pull handle is pulled out as far as it will
go and then locked in that position by turning it through 90º. This opens a bypass circuit
in the hydraulic pump unit. The soft-top can then be moved by hand.
Emergency stowage compartment catch release
The soft-top stowage compartment catch must then be released. This involves pulling the
release cable on the rear boot trim panel. The soft-top stowage compartment catch then
disengages. The release cable is on the boot bulkhead. Pulling the release cable handle
from inside the boot releases the soft-top stowage compartment catch. The soft-top can
then be raised up to the windscreen top rail by hand.
Operating the windscreen top rail lock manually:
To lock the soft-top to the windscreen top rail, the plastic trim on the front roof bow must
be removed. Below the plastic trim panel is a socket-head bolt. Using the Allen key supplied
in the vehicle toolkit, the windscreen top rail lock can then be locked or unlocked manually.
