Several times now I have come to open the roof and it starts the sequence, but then stops. It seems to get 'stuck' for want of a better word, as if the catches haven't quite unlocked.
If you press upwards very gently, this is enough to get it going and then the rest it does itself.
Is this just a matter of greasing the metal clasps or a sign of the bloody roof motor going?
EDIT: Search threw up this:
So stupid question now...
WD40 or something more exotic? :wink:
On checking the latches on the front of the roof frame and slots and rollers on the windscreen top rail they were very dry. Having soaked the latches, fittings and all the roof frame pivot points in lube it’s working fine now. Phewwww!![]()
