Hi, new Z4 owner, and mechanic by trade, and I just now purchased a Z4 with a top that doesn’t work.
I have the top out and have tried bench test it. You could always hear the motor work, and upon inspection there is very little corrosion on anything except a bit on the banjo fittings, doesn’t seem to be any leaks or anything.
I took off the motor and hydraulic lines and tested the motor, fluid will come out one side quite vigorously, but when motor polarity is reversed, very little (maybe 4-5cc’s of fluid per 30 seconds) comes out.
Is that reason enough to think the hydraulic part of the unit doesn’t work? Should there be equal flow of fluid in both ports? Can just that unit be purchased without the expensive motor?
The roof does absolutely nothing, not even try to go up or down with the motor running.
I’m hoping this will help some others, as I do hear a bit on this forum “I can hear the motor running but it doesn’t do anything” and then they go and buy the hydraulics and the motor, hope to save them a few dollars by having a proper diagnosis and test.
