Roof hydraulic hoses cut --> repair possible?
penant78
Hi,
I was getting in the process to repair a third roof motor.
I already repaired two successfully. I knew the hardest part was to remove the motor casing.
But this one was so hard to remove, I had to remove the roof.
During my attempt in making some holes in the casing, I accidently cut two of the hydraulic lines.
I know the easiest way would be to purchase new ones but I have found a specialist in the USA selling couplers to reattach them.
Is it possible to find that kind of couplers in Europe?
I'm in Belgium.
They look to be the same size hose as braided brake hoses
All the fittings etc are available from motorsport suppliers you just need the skill set to make the ends off
Here is a vender in the USA who sells hydraulic line repair parts. https://cabriolethydraulics.com/products-services/hydraulic-hose-repair-couplers/
This vender does convertible repair. I'd send them an email with your problem & ask if there repair parts will work. Ask if they will ship to you in Belgium. I'm sure the vender will take credit card or paypal so payment from eur's to dollars won't be an issue. Your country may charge some kind of customs fee.
I should note, that I'm aware of this product, but never need to use it myself so I can't tell you that it works.
Best luck with this.
