I thought it had fixed itself, and although its better sadly its still not right.
The hood has had a new motor, I have checked the rear shelf and tried the roof folds, oiled hinges etc. But still when I lower the roof, the passenger side sits ever so slightly higher than the drivers side and can only be noticed if you look square on from the rear. As a result the foor light flashes, however if I lean on the corner of the roof I can get the light to go out, but as soon as I take the pressure off that corner the roof springs back slighty and light comes on again.
So everything is working including all the micro swtiches and latches, its just the roof will not sit down 100% flat on the passenger side. So was wondering is there is a way of adjusting the hinges. I'm only looking for say 10mm or so.
If it can be adjusted in anyway, then a how too would be superb.
Thanks in Advance.
Thanks in Advance.
